  • 16 Vote(s) - 2.94 Average
water damage to FAAC photocell
My single leave swing gate stopped working. I have underground FAAc motor and 3 pairs of safety photocells. I have identified that one of the photocells has no light and its control board has water damage as per picture.  I need advice with the following questions please,
Does replacing the damaged photocell will resolve the problem of the gate not opening?
Is there a need to re-program the keyboard setting after installing the new photocell.
(11-07-2022, 04:21 PM)Rajab Wrote: My single leave swing gate stopped working. I have underground FAAc motor and 3 pairs of safety photocells. I have identified that one of the photocells has no light and its control board has water damage as per picture.  I need advice with the following questions please,
thanks for the message,
the photocell that is damaged would presumably be for the opening direction, if so then yes this will rectify the issue.
you should not need to reprogram anything.
Regards Joe
Thank you JoeF for your advice. I have ordered new photocell and will let you know the outcome once I put them on. The damaged photocell is for preventing the gate from opening if blocked.
It worked, I installed the new photocell but notice the Rx end has one light only, so went back and opened the photocell and found the two of the four cables rubber casing were damaged with wires broken 10 cm from the end inside the metal post.  Luckily there was plenty of cable length, so  cut off the damaged section and connected fresh end of cables and all is good.  Thank you JoeF! Smile
(17-07-2022, 08:15 PM)Rajab Wrote: It worked, I installed the new photocell but notice the Rx end has one light only, so went back and opened the photocell and found the two of the four cables rubber casing were damaged with wires broken 10 cm from the end inside the metal post.  Luckily there was plenty of cable length, so  cut off the damaged section and connected fresh end of cables and all is good.  Thank you JoeF! Smile
Hi Rajab,
Glad to hear.
Easygates
  FAAc xp20d wiring Neil Young 4 6,157 04-02-2025, 12:08 PM
Last Post: Neil Young
  FAAC gates out of sync TheDock 1 3,477 21-08-2024, 12:21 PM
Last Post: TheDock
  Faac 452 pcb board benner91 2 6,834 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 8,340 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  Photocell Problem marcoos_1 4 28,801 04-01-2024, 10:23 AM
  FAAC E124 fault 05 allan@amtas.com.au 0 3,627 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 9,152 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 4,463 23-06-2023, 03:19 PM
Last Post: Alpin
  FAAC Photocells mmc1977 3 8,418 02-05-2023, 12:37 PM
  Proteco gates with photocell problem. Shane1 0 4,201 09-10-2021, 07:56 PM
Last Post: Shane1
