  • 19 Vote(s) - 2.68 Average
BFT Thalia button
Have a BFT Thalia l, I was going to add a push button to control. I understand it needs to go between 60 and 61 fine.
It says is default is Start E, what does start external mean. What's the difference between Start E and Start I?
(13-04-2022, 05:46 AM)djbananas Wrote: Have a BFT Thalia l, I was going to add a push button to control. I understand it needs to go between 60 and 61 fine.
Thanks for your message,
There realistically isn't much difference between the logic of START E and START I, both of these will follow a STEP-BY-STEP logic of which means you can open, close and stop the gate from the push button, the only difference is if the gate controller utilises traffic lights as this will trigger the corresponding output for the traffic light.
Hope this helps.
Kind Regards
Thanks Joe. Makes sense.
Connected up and its works all fine
(14-04-2022, 07:45 PM)djbananas Wrote: Thanks Joe. Makes sense.
Thanks for the reply,
Glad to be of help.
Kind Regards
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,160 03-02-2025, 12:24 PM
  BFT Thalia no power on accessory ports (50, 51) tjomk 2 4,705 22-10-2024, 02:54 PM
Last Post: Bigmac3112
  Thalia - Photocell Close J to the D 1 3,923 19-01-2024, 09:54 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 13,739 24-08-2023, 01:38 PM
  Thalia P - Wireless control board module mathewnorris22 1 6,923 02-03-2023, 03:17 PM
  thalia error code 3h 35/37/38 detritus 1 6,181 05-01-2023, 11:54 AM
  BFT Thalia GSM gate opener SunnyB1 1 6,560 07-03-2022, 10:58 AM
  Lux/Thalia P ersl error Dava12 0 4,890 13-12-2021, 09:35 PM
Last Post: Dava12
  Gates not closing (BFT Thalia btl2 and Bft Desme) Joel23M 2 12,116 17-01-2021, 01:25 PM
Last Post: Joel23M
  Thalia P issues Dave G 4 20,251 25-05-2018, 09:06 AM
Last Post: Dave G
