  • 15 Vote(s) - 2.87 Average
what size allen key for liftmaster gatestop and bolt?
I need to change the hinge fixing on my liftmaster gates.  I got the parts but I need to transfer the gatestop from the old to the new but it is held with a nut that needs an allen key.  What size allen key do I need?  I should explain when I try to undo bolt the whole thing rotates.
Also what size is the bolt that hold the hinge to the motor and where can I get them?
Thanks.
(29-05-2021, 11:51 AM)bomitie Wrote: Hi
Thanks.
I am unsure of the exact key size needed. I recommend purchasing an allen key set and going through a trial and error sequence, you can pick up a set fairly cheap from the local handyman. I recommend gripping the nut with an adjustable spanner whilst using the correct size allen key to loosen the bolt. You can also take the bolt to a local handyman, these items are fairly common and stock of them should be readily available.
- Jamie
Thanks for reply. I did a bit of searching while waiting for a reply and in the end I ordered the 2 complete bits, its called LiftMaster SUB-110 110° Opening Gate Arm. The gates are up quite a while so I am going to replace the lot except the gates. I get all I need and the gate stops are included. I will keep the other bits as spares.
  Liftmaster CB1 / SCS300K - left arm only engages after release then reengage telnet123 2 12,273 10-10-2023, 09:28 AM
  gate stop broke - any spares=liftmaster 300 bomitie 2 13,352 04-05-2023, 04:02 PM
  Liftmaster scs Athers 1 23,030 30-10-2020, 10:11 AM
  Liftmaster scs Athers 0 19,755 19-10-2020, 08:08 PM
Last Post: Athers
Rolleyes Cantilever gate size Wilky18 1 9,485 15-04-2019, 09:13 AM
  Liftmaster LYN300K, 400K zappahead 1 30,567 12-04-2018, 03:30 PM
Last Post: Tim
  Wanted - Liftmaster SUB300M Motor pigsfoot 1 24,060 03-06-2015, 04:07 PM
  >> Liftmaster CB11 Support Diagrams << easygates 1 32,597 27-04-2009, 12:49 PM
  >> Liftmaster CB24 Support Diagrams << easygates 3 39,644 27-04-2009, 10:58 AM
  >>> Liftmaster CB24 Simple Setup Guide <<< easygates 0 22,698 30-03-2009, 04:27 PM
