  • 27 Vote(s) - 2.63 Average
BFT Deimos BT A600 fault Error 10
I have an error 10 on BFT Deimos BT A 600. Manual states possible motor opening/closing
Contacts are seized.
Can any member advise where new relays for BFT Merak 600 can be purchased.
Relays are   WGR 24vdc.  RD - 124D - H1.      H2023J
Thanks in advance for any assistance,
(23-05-2021, 03:28 PM)Airbus330/300 Wrote: I have an error 10 on BFT Deimos BT A 600. Manual states possible motor opening/closing
hope you are well,
unfortunately you cannot purchase this part as a spare and therefore a new control panel will need to be purchased on this occasion
Regards Joe
hope you are well,
Regards Joe
Hi Joe,
Thank you for the prompt reply.
When testing resistance reading with a multimeter on the motor on BFT Deimos Ultra BT A600,
what should be the resistance reading be?
Many Thanks
Regards Gerry
hope you are well,
Regards Joe
Hi Joe,
Many Thanks
Regards Gerry
Hi, i found your message here about BFT Deimos BT A 600 ERROR 10, Can you please tell me was was the fix? since i have exactly the same error now Sad
hope you are well,
Regards Joe
Hi Joe,
Many Thanks
Regards Gerry
Error 10 is indicative of the following faults...
ER10
(BT motor)
Motor 1 relay running faulty test
- Motor 1 relay running control circuit failure
- Relay with stuck contacts
- Short circuit mosfet
- Check and remove the causes of possible high absorption of motor 1
- Reparation: replacement of shunt resistance, relay control circuit components, mosfet
It could be any of the following issues which may require replacing the faulty item.
hope you are well,
Regards Joe
Hi Joe,
Many Thanks
Regards Gerry
ER10
(BT motor)
Hi, I already replaced the PCB and unfortunately the error still occur (probably the new PCB also damaged!). Motor was tested with 24v transformer and it was working without any issues
what else i can check?
  Question BFT Deimos A400 Makaroni 2 4,934 07-05-2025, 05:58 AM
Last Post: OnionBobo
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,396 15-10-2024, 10:37 AM
  bft deimos ultra bt600 error f1 pfloyd 4 8,438 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT deimos smoke from board stanli200188 1 4,273 05-03-2024, 04:17 PM
  thalia error code 3h 35/37/38 detritus 1 6,228 05-01-2023, 11:54 AM
  Lux/Thalia P ersl error Dava12 0 4,930 13-12-2021, 09:35 PM
Last Post: Dava12
  BFT Submotor fault Rockford 0 6,323 18-05-2020, 09:42 PM
Last Post: Rockford
  ERROR 11 TheoLouloudis 0 11,924 10-09-2019, 08:52 PM
Last Post: TheoLouloudis
  BFT Deimos Ultra remote problems shaggy 1 14,852 01-05-2019, 09:43 PM
Last Post: ok.dude
