  • 21 Vote(s) - 2.81 Average
Rigel 6 - doors do not stay open
I have a Rigel 6 system and someone was fiddling with it and now the gates do not stay open as they did before- all the day/hour timer settings are set but after opening the gates, they close when you drive through them rather than staying open. Sure it’s just a simple fix but what setting should it be on to sort this out- is it to do with automatic residential or something else.
Thanks in advance!
(04-04-2021, 10:51 PM)Poweroftaxi Wrote: I have a Rigel 6 system and someone was fiddling with it and now the gates do not stay open as they did before- all the day/hour timer settings are set but after opening the gates, they close when you drive through them rather than staying open. Sure it’s just a simple fix but what setting should it be on to sort this out- is it to do with automatic residential or something else.
Thanks in advance!
I hope you are well. Do you want the gates to stay open until they are sent a command to close? Or do you want the gates to stay open for a specific amount of time before automatically closing?
If you would like to set automatic closure this is set in the parameters section of the manual - 'tcA' (automatic closing time).
If the gates are closing as soon as you drive past them, check where your photocells are being wired into. If the photocells on the side of the property you are driving towards are into the close terminals this will reverse the gate. Also, check you have not set the tcA to a very small amount of time.
You will be able to find this information in the Rigel6 manual linked below.
https://manuals.easygates.co.uk/PDF/misc...manual.pdf
Kind regards,
-Jamie
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,429 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,195 26-03-2025, 12:07 PM
Last Post: Talonfinger
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,232 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,574 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 5,063 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,366 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,912 17-07-2024, 02:24 PM
  BFT Rigel 5 issue Adamit 0 2,890 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 18,210 04-05-2024, 12:47 PM
