  • 19 Vote(s) - 3.11 Average
But Rigel 5 and Deane a15 cells
Hi there
I am having a nightmare with the above. I have the gate, fobs and keypads working fine. When I try to connect the cells they don’t work. I have been through all the combinations listed in the manual with no joy. Can anyone please give me a definitive wiring description and advise as to what I need to set the control board to. I have 2 pairs of the cells in the system. Thank you in advance.
What is the desired configuration of your photocells?
Would you like them to work close only, open and close or open only?
Thanks for the reply
I would like them to work open and close, with stopping and then continuing without full reverse.
If I connect the front cells with no test in logik menu they work. Same goes for the rears. If I connect both then neither work.
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,440 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,199 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,581 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 5,069 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,373 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,892 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 18,215 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,477 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,940 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 7,238 05-01-2023, 11:53 AM
