  • 20 Vote(s) - 2.8 Average
Hello Looking for gate control help
Hey there I'm looking for help with a FAAC 401 gate controller, I can hear it activating (something clicking on the board) but gate doesn't move.  Where should I start troubleshooting?
(31-01-2021, 05:11 PM)everettc4 Wrote: Hey there I'm looking for help with a FAAC 401 gate controller, I can hear it activating (something clicking on the board) but gate doesn't move.  Where should I start troubleshooting?
The clicking you can hear on the board is presumably the relay activating. This is completely normal. Have you completed the initial setup of the gate? As you will not be able to simply plug and play, the open and close limits will need to be programmed and devices will need to be learnt in. If this has not been done the gate will not operate. You should be able to find the step by step setup guide in the manual provided with the kit.
If you have completed the learning stage on the panel and the gate is still not operating, you can check the panel for diagnostics. A flashing light should appear on the panel, each sequence of flashes can be linked to different fault diagnostics in the manual.
I would also check that the photocells are in line and are not obstructed by anything, as if obstructed the gate will not open. Continuity of the cables could also be checked. You could also check the voltage going to the photocells. I believe the photocells for the FAAC 401-MP have 30v D.C going into terminals 5 on the receiver side 2 on the transmitter side.
Voltage from the motor terminals could be checked also.
-Jamie
  Gibidi gate opener. Add a wired switch. Eagle_man 1 12,548 30-11-2021, 01:23 PM
  Beninca sliding gate. Rogeramjet 1 9,418 22-11-2021, 06:14 PM
Last Post: Asaded
  Wiring control panel apritech mach2 230v brian 32 156,299 27-11-2019, 10:15 PM
Last Post: brian
  GIBIDI gate motor closing problem davidcunningham 0 11,081 26-04-2019, 07:46 PM
Last Post: davidcunningham
  Inherited GiBiDi Gate Shuggy73 2 16,203 13-04-2018, 05:18 PM
Last Post: Shuggy73
Cool Hello :) Gate/Barrier Engineer MrDiagnostics 0 9,364 29-04-2017, 09:48 AM
Last Post: MrDiagnostics
  Mhouse Swing gate rmgsecurity Sri Lanka 0 8,459 12-11-2016, 03:00 AM
Last Post: rmgsecurity Sri Lanka
  BFT electric gate Er 35 Chantal 0 8,864 28-11-2015, 07:57 PM
Last Post: Chantal
  Q80A Control Box Paj 0 8,666 03-09-2015, 07:36 PM
Last Post: Paj
Wink Geniss Gates with Genius BRAIN 03 Control Board 4LPS 3 22,113 10-08-2015, 09:31 PM
Last Post: 4LPS
