  • 21 Vote(s) - 2.24 Average
Advice on new gate install - LIFTMASTER LYN424
New to this forum and hoping to gain advice that I am purchasing the correct openers?
I have been recommended the Liftmaster LYN 424. I am a mechanical engineer and my son is an electrician so I'm fairly confident that we should have the necessary skills to install correctly.
I have a couple of questions:
  1. I think that I will need to fabricate/weld the provided motor brackets that install to the gatepost?
  2. I'll need to run cat5 cable to the second motor which provides power and automations?
  3. Not sure where I could put the photocells as have a 90 degree turn to make entering and exiting our property?
  4. Do I need the photocells for this model? as it states "It also boasts stop and reverse obstacle detection which is unique to the 24v operators for added protection"
I have added a couple  links below of our entrance which should make it easy for comment. PS: We have decided against underground automations.
Would really appreciate your help and advice on this forum.
Thanks - Lee
[Image: uc?export=download&id=1tpeoALFUPF52GW9FixlXFTyKTp7oocw4]
[Image: uc?export=download&id=1Fnj2EIkVAHx9oQipEzCPqxbQ_OyicAAx]
[Image: uc?export=download&id=1PToTg9O-TevjVeUziOKaqqlrPVjte52E]
Hiya Leeb,
Answers to your questions.
1. It will be better for you to fabricate a motor bracket. As brackets in kits are not the best.
2. Do not use cat5, alarm cable, or any other cable where you can gate massive amounts of it for a fiver. You will get problems in the future. And you are out in the open. Water and moisture will corrode cheap cable. Do not skimp on your cable. Use a decent multicore cable. Just having a quick look at Liftmaster LYN 424. It pulls 2 Amps.
3. Photocells can go on your gate posts. You can use wireless photocells if you want. Buy brand name photocells. Do not get Ebay specials.
4. Without going into it. ( this is not the place for a rant ) Not a fan of this obstacle detection. I am safe edges and laser scanners. But in your situation. You are in the middle of nowhere. And you and your lad are automating your gate. It is down to you to make the gate safe.
Also. 24volt equipment is very sensitive. Sometimes to sensitive. How windy is it at your place.
5. If you look at gate safety DHF. It will give you an idea on safety for electric gates.
Regards,
Russ.
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 323 Yesterday, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 27,089 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Sun affecting gate opener ForestRon 2 11,969 02-09-2024, 03:54 PM
Last Post: ForestRon
  Liftmaster LA400 Defender 6 22,280 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 21,461 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 19,382 09-03-2021, 02:46 PM
Last Post: Carmody
  Loose gate stop but what wrench to use? bomitie 2 13,829 02-04-2020, 12:06 PM
  Liftmaster CB1 gates started to open themselves telnet123 4 35,391 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,628 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,104 08-08-2017, 11:23 AM
