  • 32 Vote(s) - 2.97 Average
Gate wont close issue
Hi all, I have had a good read of a lot of threads on here and can’t see the to find my exact issue.
I have a sliding electric gate (BFT Deimos Ultra BT A 600) and after opening it this morning it now wont close.
The LCD on the PCB displays Phcl  which from looking at manual is PHOT CL closing photocell input activated.
It is raining outside and I’m wondering if this has caused the issue with ingress causing a problem with one of the photocells.
I am a bit new to the diagnostics of these issues so any help would be appreciated.
There are two sensors on the sliding gate which align when open/close with a sensor on the ground unit.
There are two static photocell sensors on either wall of the gate entry which I’m assuming is the safety beam aspect.
Is the Phcl error to do with the ones on the wall?
Hope you can help.
Turns out I solved this myself in the end.
It was the battery in the photocell TX/RX module on the wall. Just needed a new 3V battery (size C2).
Figured I’d leave the post here just incase it helps anyone else with similar situation.
Apologies if basic user error for most people.
(04-07-2020, 01:10 PM)MR_ROBOT Wrote: Turns out I solved this myself in the end.
hi Mr Robot... i think i have the same issue. I can't work out exactly where the battery is...
benj
benj
if you have battery photocells they will be on the RX side of the photocell set. you may have a hard wired system which would mean you do not have a battery photocell.
  BFT Gate Motor - Not working elyoussef.ali 1 6,390 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,150 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,423 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,227 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,708 04-11-2024, 05:59 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,385 15-10-2024, 10:37 AM
Last Post: Sootylfc
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,907 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,043 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,122 23-05-2024, 06:35 PM
Last Post: Zhymke
  BFT Rigel 5 issue Adamit 0 2,885 17-05-2024, 10:28 AM
Last Post: Adamit
