  • 19 Vote(s) - 2.74 Average
Sliding gates are opening/closing like someone is going in /out.
Chemberlain LiftMaster Model ECO300.
From time to time I have a big problems. Sliding Doors are opening/closing like photocell been disruption.
like someone is passing in / out.
Every time "click" from relay inside the control box, is heard.
Please help!
Best Regards
Andreja
(03-04-2020, 12:12 AM)gandreja Wrote: Chemberlain LiftMaster Model ECO300.
Please help!
Best Regards
Andreja
HI Andreja,
are you using cells as a means of opening or a means of additional safety?
it sounds to me that there is either a short in the command inputs or a short on the cells if they are used for a means of opening or closing.
a way to test this is to disconnect all pushbuttons intercoms ect and see if this still happens i am confident this is the issue and all that will be required is to replace the cable.
Many thanks for answer!!!
These photocells are for opening and closing.
I think. Not sure. This is the explanation and wiring is attached.
If gate is open. after passing through the bean, gate wings are closing.
If gate is in phase of opening, passing through the bean is going to stop the gate. For a moment.
If gate is closing, passing through the bean is going to open the gate wings.
Where can I buy spare parts?
This definitely sounds like there is something giving a command to the gate, such as a shorted input cable from a keypad or other. However it could be faulty photocells. spares can be found on easygates.co.uk
  My swing gates are stuck at 50% open jctrotting 1 4,559 11-04-2024, 08:11 AM
  Liftmaster CB1 gates started to open themselves telnet123 4 36,381 01-01-2020, 09:43 AM
Last Post: pronosoft
  CB1 How to learn the gates telnet123 1 18,642 30-04-2018, 01:45 PM
Last Post: Tim
  Liftmaster sliding gate Kar1e 1 20,477 08-08-2017, 11:23 AM
  5580-GB - reverses after opening ... adambc 1 10,913 27-05-2017, 08:44 PM
  Opening delay on SCS300 (CB124 board) willows79 0 10,617 02-12-2015, 09:45 PM
Last Post: willows79
  Gates dont close after being held open jaybee 1 15,736 18-06-2013, 09:23 AM
Last Post: Blakey111
  garage door opening on its own akhls 1 14,353 14-08-2009, 05:54 AM
Last Post: protectrix
  Gate opening all on it's own Nan 1 17,750 02-03-2009, 05:35 PM
  Art300 opening angle 1 14,875 02-03-2009, 05:15 PM
