  • 15 Vote(s) - 2.87 Average
Liftmaster CB1 gates started to open themselves
My Liftmaster gates have, as of yesterday, started opening themselves. Yesterday my keyfobs (4 of them) started to either not work or only one of the gate opened. I tried to reset by turning off/on the power and even tried to re-learn the keys. But still only the one gate opened (CH1). After leaving for a while I retired the gates via the keypad and both gates opened and then the keyfobs started to work again. Later I found the gates were fully opened so I closed them. At 3AM this morning I heard them open, so I closed them and then 10-20mins later I heard them open again so I turned off the power. This morning I powered them back on and later found them open again.
I hope this if of some assistance.
(23-12-2019, 04:16 PM)RyanB Wrote: Hello,
Thanks RyanB - Are you able to give some guidance on what terminals I need to disconnect for the keypad?
Ok - after speaking to your helpful support team it was mentioned moisture could be the cause, so I have cleaned and dried out the "weatherproof" box containing the CB1 board and the SRS switch and sealed any holes with sealant. This appears to have resolved the issue. I now have another issue where only one gate opens after reprogramming. I'll raise another post for this.
  Liftmaster MYQ Internet gateway koen_dc 4 25,993 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  My swing gates are stuck at 50% open jctrotting 1 3,842 11-04-2024, 08:11 AM
  Liftmaster LA400 Defender 6 20,953 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 20,442 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 18,601 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 22,670 22-02-2021, 08:48 PM
Last Post: russ
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 13,569 14-04-2020, 01:45 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,079 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB1 How to learn the gates telnet123 1 18,040 30-04-2018, 01:45 PM
Last Post: Tim
  Liftmaster sliding gate Kar1e 1 19,714 08-08-2017, 11:23 AM
