  • 12 Vote(s) - 2.25 Average
WG20S not flashing
Hi - I have a WG20S single gate system which has suddenly stopped flashing its beacon, however the gate operates normally. There is an EL1 electric lock interface controlling a lock on the gate, and the lock has now starting pulsing when the gate is in operation as if it is receiving the flashing signal. I have replaced the EL1 with a new unit but this has had no effect. The ECSBus led is flashing once every second (normal) and the STOP led is permanently on (normal). Beacon bulb checked and is ok.
Can anyone shed any light on where the problem might be?
Sorted. Wiring to beacon had corroded.
  Robus 600 not opening - Bluebus flashing DaveB 1 12,872 27-03-2020, 06:14 PM
Last Post: DaveB
  Mindy A824 Controller - OK Light Flashing ColinS 5 33,166 02-01-2020, 08:19 AM
Last Post: pronosoft12
