  • 6 Vote(s) - 2.5 Average
FAAC Configure 443Hz remote to open partially, pause and close
Hi all,
I just moved in and stay in a shared apartment with a FAAC Sliding Gate System.
Currently I have a 443Hz remote with 4 buttons that is able to open the gate fully, the gate will auto close in 10 seconds.
And there is a physical switch at a side door that will open the gate partially.
How can I find out the frequency and configure in the 443Hz remote to
- Open the FAAC gate partially
- Pause the FAAC gate opening / closing
- Close the FAAC gate
I suppose the frequency will be the same for opening partially, pause and closing the gate?
Appreciate if there is any information / clue that I can learn here or figure out
(07-08-2024, 11:40 AM)Ezylryb Wrote: Hi all,
You will need to program the remote through a step by step function.
Could you please provide the model number of the gate control panel.
Jake.
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 2,647 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 2,491 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 2,663 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 2,100 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 6,974 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 5,451 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 6,474 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 5,322 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 10,674 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 10,329 14-11-2022, 12:03 PM
