  • 19 Vote(s) - 3.05 Average
Beninca R1.6E - Photo Cell Issue
Hi All
I do not normally use forums as most problems I can resolve however this one has stumped me and I do not have the appropriate wiring diagram.
Ten years ago I built and installed a sliding gate system using a Beninca R1.6E drive unit coupled with a Daitem intercom which has worked with no issues up until recently.
I now saw  that the photocell beam is not stopping the gate when broken Sad
I have checked the TX RX and the relay is clicking as it should but the signal does not stop the motor.
I wired this lot up ten years ago and do not have the wiring diagram, however to change the complete Beninca unit may be a bit extreme. I have checked all the terminal connections they are all fine with no corrosion.
Any thoughts would be welcome.
  Faulty Beninca RF transmitter for safety edge JKR2 3 5,067 26-07-2024, 10:20 AM
  Beninca motors and Control unit sergomes 2 30,982 10-12-2016, 01:18 AM
  Combined remote for Beninca/Cardale? londonthing 0 10,588 22-10-2016, 05:35 PM
Last Post: londonthing
