  • 135 Vote(s) - 3.33 Average
came bx-74
Can some one help me please replaced a came bx-74 everything went perfect till i wanted to get the remote control set up.Came manuel says dip 4  keep 3 off dip 10 need to turn 4 7 8 9 on press chanel 1 gate should open and close and led goes solid then dip 10 turn 4 7 8 9 off and remote will be linked to the unit and gate should open and close.after pressing the ch1 gate does opens and closes then remote does not link ....Any help will be really appreciated. Thank you in advance
Thank you for your enquiry, can you let me know what remote you are trying to program into the Came system and i can then send you programming procedure and also maybe a video for a visual reference.
Kind regards
Tim
