  • 191 Vote(s) - 3.14 Average
Exit realease button mag lock farfisa wiring
Hi, I have a farfisa fc52pl and struggling to get my head around on how to wire it to a magnetic lock. Can some one help,
On the 12vdc magnetic lock the connection are +,-, no,nc, and c
I'm using a itw push to exit button which has 4 wires,
the two wire outer wires white and black are normally open
The inner two are red and blue are normaly closed.
The farfisa relay does seem to be switching as I can hear it when I press the push to exit button, but not releasing the lock
Any help or a wiring diagram would be much appreciated thanks
(24-05-2017, 03:34 PM)Harry Wrote: Hi, I have a farfisa fc52pl and struggling to get my head around on how to wire it to a magnetic lock. Can some one help,
To wire the FC52PL to a maglock you would need a separate 12v power supply and wire this in series with the keypad and maglock.
you should wire this as follows..
C1 on keypad to - on maglock, + on maglock to + on PSU, then - on PSU to NC1 on keypad. Do away with the NO, NC and C on the maglock as you do not need these.
I hope this helps!
EasyGates.co.uk
EG Direct - Trade only
Thank you so much Ryan il give that ago,?
  BFT EBP24 lock info tonivan belle 1 20,413 17-08-2019, 12:05 PM
  CB11 Emergency close button Ronn 3 21,242 14-01-2017, 11:30 AM
