  • 316 Vote(s) - 2.81 Average
Gate closing but not opening
Question
Hi, I have a BFT Sliding Automatic gate with Deimos motor using Mitto fobs for remote opening / closing. Installed about 5 years ago. Gate is opening but not closing. It moves about 6 inches back to close and then gets stuck ? What should I check or look for please ? Simple instructions please I'm a woman ! ALL advice very Smile welcome.
Kindest Regards,
Dave
Dave Blake
Thank you Dave. Will try and let you know.
(12-06-2014, 09:26 AM)Blakey111 Wrote: Hi,
Kindest Regards,
Dave
Hi Dave
Problem solved. It was the spring that was disengaging from the bent "arm"....thank you for your help...Smile
Kindest Regards,
Dave
  BFT Gate Motor - Not working elyoussef.ali 1 6,390 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,150 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,423 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,227 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,708 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,385 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,908 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,043 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,122 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 17,262 11-04-2024, 08:08 AM
