  • 299 Vote(s) - 2.96 Average
Art300 opening angle
I am thinking of buying a dual Art300 kit to open my gates. However I was wondering is it possible to program each actuator to open each side to a different angle. My driveway turns slightly inside the gate so on one side I would like the gate to open more than 90 degrees (maybe 110) and on the other side I would like the gate to open less than the 90 (maybe 80) .
Yes the Art300 kit would be suitable for your needs as it opens upto 120 degrees (aslong as the geometory is correct). You can adjust them to open as far as you want upto 120 degrees, by adjusting the built in limit swiches which you rotate to set them where you desire. You can also do the same on the closing.
Hope this helps.
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,626 14-04-2020, 01:45 PM
  5580-GB - reverses after opening ... adambc 1 10,907 27-05-2017, 08:44 PM
  Opening delay on SCS300 (CB124 board) willows79 0 10,611 02-12-2015, 09:45 PM
Last Post: willows79
  garage door opening on its own akhls 1 14,349 14-08-2009, 05:54 AM
Last Post: protectrix
  Gate opening all on it's own Nan 1 17,748 02-03-2009, 05:35 PM
