  • 369 Vote(s) - 2.87 Average
LYN300 closing problem
My kit has been working OK until today, now the gates wont close and the close edge (on gate post) photo cells' red LED glows constantly even if the beam is interrupted. The red LED on the control panel (on the close edge) is also permanently on and I can't seem to get it to turn off. Any clues as to whats wrong????
Furhter investigation reveals; with nothing connected to 'close photo' input, the red LED adjacent to that input stays lit even though switch 5 of S1 is set to normally open.
With switch 5 set to normally closed and a wire bridge in 'close photo' input then gates work OK but the close sensor is obviously not functioning. sounds like a main board failure to me but expert opinion would be appreciated.
whitegatenorm Wrote:Furhter investigation reveals; with nothing connected to 'close photo' input, the red LED adjacent to that input stays lit even though switch 5 of S1 is set to normally open.
This sounds like a Photocell problem if the lite goes out with the contacts bridged out.
Double check your connections to the photocell and make sure they are lined up then switch save switch off to see if the lite goes out if it does then switch save back to on.
The circuit needs to learn the saftey circuit by switching the save switch off for 20 second then back on
If this does not cure the problem then you would need new photocells
Thanks Mark, I've tried this and the problem persists, which seems to indicate the photocells. I'll ring you in the week as the whole kit is only about 3 months old
[quote=whitegatenorm]
Thanks for the advice Mark, and also thanks for the extremly prompt service in replacing the faulty photocells, I've not fitted them yet but expecting a complete cure when I get round to it. Once again many thanks for your efficient service
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 8,996 02-03-2023, 03:12 PM
  Problem with delay time CB11 milan 2 14,956 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Lyn300 lubrication Capricious 5 17,081 08-06-2021, 12:37 PM
Last Post: Capricious
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,111 14-04-2020, 01:45 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,635 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB22 problem??? Bakota 0 10,718 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 12,130 30-09-2014, 04:48 PM
  liftmaster CB11 hold gate open problem sparkey 5 37,440 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 14,024 08-05-2013, 11:32 AM
  LYN300/400 thermiclance 0 8,873 29-10-2012, 08:58 AM
Last Post: thermiclance
