  • 27 Vote(s) - 3 Average
BFT Deimos issue
Hi All,
I've got a BFT Deimos 600 sliding gate opener.
The gate wouldn't open and noticed that there was no power to my access keypad either.
Opened the controller box and found that one of the fuses has blown which seems to distribute the 24v to the safety devices.
There are two fuses on the board. A 1.25amp and a 800ma. It is the 1.25amp that is blowing.
I replaced the fuse and the 24v was there again, until I tried to open the gate and it opened but the fuse blew immediately. The gate continued to open fully but was then stuck open as the 24v for the safety devices was gone.
I have the gate open and fuses replaced and the LCD display is SLo (Leaf open) but as soon as I give a command to the gate, the fuse pops and the LCD displays PHCL (Closing photocell). I assume this message appears as the 24v has dropped to the photocell and the controller assumes it is not in the correct state.
Any ideas what to do next? I bridged out the normally closed contacts for the photocell at the controller, ran the gate and got an error code ER04, which relates to the photocell too.
I'm at a bit of a loss here and would appreciate any help.
It turned out that the 24v flashing beacon on the gate was faulty and became short circuit, which was blowing the fuse. Disconnected it and all is working again
(16-06-2025, 07:32 AM)erickavo Wrote: It turned out that the 24v flashing beacon on the gate was faulty and became short circuit, which was blowing the fuse. Disconnected it and all is working again
Brilliant I am glad that the issue is resolved, we can supply a replacement unit should you need one please enquire at info@easygates.co.uk
  BFT Demios A600 bAr issue Rohbot15 2 2,091 15-08-2025, 01:41 PM
  Genius JA592 issue fintaneduffy 3 5,854 19-01-2024, 09:58 AM
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,926 25-05-2023, 03:55 PM
Last Post: Kaala1
  BFT IGEA BT issue warren5 1 5,778 13-04-2022, 11:49 AM
  Beninca BOB21m Photo cell issue Rossm1987 1 7,812 02-05-2021, 12:39 PM
Last Post: Rossm1987
  Deimos BT 400/600 error codes orange 0 6,087 07-12-2020, 09:36 AM
Last Post: orange
  BFT C130 Photocell Issue labbetts 0 5,982 25-01-2020, 05:01 PM
Last Post: labbetts
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,538 28-11-2019, 12:11 AM
  Strange gate opening issue (NICE) FrNiscars 3 29,064 09-11-2018, 09:48 AM
  Nice a60 opening issue raven2k1 1 10,454 09-09-2018, 05:17 PM
