  • 12 Vote(s) - 3.08 Average
BFT key pad not communication with digital board
Hi all,
BFT keypad has suddenly stopped working with the gate.  Batteries appear fine, code registers fine on the key pad triggering a green light.  However it appears that the pad no longer communicates with the main digital control board.  I’ve tried re pairing, this process also does not seem to work (in terms of kicking out an OK followed by a number on the LCD.
Any suggestions in terms of next steps.  Thanks in advance for your help!!!
What's the model number of the keypad? I can take a look for you
Mike
  Faac 452 pcb board benner91 2 6,831 09-02-2024, 06:13 PM
Last Post: NormanY
  Replacement Q60A board? ndyhzlwd 1 5,826 10-02-2023, 03:19 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,188 02-12-2022, 02:51 PM
  Beninca bob motor wiring to board Ranch2 6 13,596 18-11-2022, 09:59 AM
  CAM ZA3 Single control board Rookie 1 11,122 13-04-2022, 11:37 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,605 02-05-2021, 09:00 PM
Last Post: soother
  Older FAAC gate no power to circuit board tfb208 0 9,995 19-11-2020, 06:10 PM
Last Post: tfb208
