  • 26 Vote(s) - 2.69 Average
Replacement Q60A board?
Hi, the house we moved into a couple of months ago has double gates controlled by the board above. The gates worked initially when we moved in, but given the traffic in/out of the drive, we just left the gates open. Since then the board has become faulty and beyond repair (within a reasonable cost anyway).
After a bit of searching it looks like there's a newer version of board, also a Q60A.
Is the new board a like-for-like replacement? Can I just swap-out all the existing connections? If not, what are the differences and can you advise/recommend solutions?
I've attached a couple of pics of the current/new boards for reference. Apologies if I've not included enough info - please let me know if you need more detail.
Thanks in advance
Andy
(10-02-2023, 11:46 AM)ndyhzlwd Wrote: Hi, the house we moved into a couple of months ago has double gates controlled by the board above. The gates worked initially when we moved in, but given the traffic in/out of the drive, we just left the gates open. Since then the board has become faulty and beyond repair (within a reasonable cost anyway).
Thanks in advance
Andy
We ourselves don't stock Proteco parts so our knowledge is limited. But from a quick internet scan, i can see that the control board you have attached is the replacement. The terminals may be slightly different so you may need to rewire and do some cable management when retrofitting the new board.
  q60a stevea 1 2,687 23-08-2024, 12:14 PM
Last Post: stevea
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 3,812 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 6,832 09-02-2024, 06:13 PM
  Replacement remote Chindley 1 6,311 06-12-2023, 03:00 PM
  TC fault code on Q60ar control board Skydive1710 3 10,134 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,736 26-09-2023, 05:32 AM
Last Post: max666
  Replacement Above Ground Mechanism Advice Amadeus 0 2,562 29-07-2023, 12:47 PM
Last Post: Amadeus
Exclamation Proteco Q60A stopped working xCO 0 3,514 19-06-2023, 01:03 PM
Last Post: xCO
