  • 22 Vote(s) - 3.09 Average
BFT Rigel 5
Hi there,
We have just replaced the posts that were housing one pair of photocell sensors to our gates. That meant disconnecting and rewiring the photocelles. Everything has been replaced as it was however on inspection there is now no power to the control unit at all. All fuses seem to be ok.
I wonder if anybody has any ideas? There is nothing showing in the LCD.
Thanks much!
You will need to check the board is still receiving its mains feed in by using a multimeter, or checking the supply RCD hasn't tripped. If all of this checks okay you may need to check the board does not have any damage on it from insects on the back of the PCB by removing it from its enclosure and looking at it.
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,426 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,193 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,571 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 5,056 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,359 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,889 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 18,208 04-05-2024, 12:47 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,462 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,933 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 7,225 05-01-2023, 11:53 AM
