  • 291 Vote(s) - 2.55 Average
CB24 - Intercom Release
My intercom has the usual NO/NC/Common setup. When attach
CB24Common --> Common -> NO -> CB24Single
the gate immediately opens. Intercom NO to common is showing high resistance normally and low resistance when enabled but does not click so I'm guessing it's an electronic changeover rather than a voltage free relay. The CB24 common output is registering about 42V which seems high as the manual suggests 24V. Is that normal and could the combination of 42V across an electronic switch be the cause of the false triggering? This must be relatively common, is the solution a discrete relay to drive the CB24 to common input?
Thanks.
Hi, Please call us so that we can resolve your problem as there seems to be some confusion.There should be no voltages involved in triggering the gates to open and you may be using the wrong connections.
  CB24 delay to close random fault stuartdsutton 0 10,180 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,662 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,455 20-08-2012, 09:40 AM
  Wiring relay to CB24 magga 4 25,558 01-08-2012, 06:35 PM
Last Post: magga
  cb24 photocells devonaloan 1 13,563 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 18,965 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB11 control box Intercom release button not working Moreteyne 0 10,653 14-09-2011, 03:14 PM
Last Post: Moreteyne
  CB24 Problems andydday 3 22,224 06-02-2011, 11:39 AM
Last Post: Guest
  CB24 Kit with a single set of photocells JD1765 1 22,963 07-06-2010, 10:04 AM
  CB24 / EasyBKA cliff finch 2 17,799 25-03-2010, 09:25 PM
Last Post: cliff finch
