  • 255 Vote(s) - 2.83 Average
Genius 452/455 Learning Issue
#11
Hi there
Just to let you know the gate is now programmed and working perfectly.
Thank you for all you help.
The reason for it not closing was a broken IR beam sensor.
Cheers again
(03-01-2017, 07:14 PM)Automatic-TC Wrote:
(03-01-2017, 10:27 AM)Robedj Wrote: Im assuming that I can simply disconnect these safety devices, program the gate and then re connect again?
you dont have to disconnected any devices .
I have a similar problem with a Brain 16 control board , it seems to have lost its ability to accept the learning times ,
question: is there any simple learning procedure with Brain 16 just like JA574 used to have
  BFT Demios A600 bAr issue Rohbot15 2 2,090 15-08-2025, 01:41 PM
  BFT Deimos issue erickavo 2 3,088 09-07-2025, 11:34 AM
  Genius JA592 issue fintaneduffy 3 5,845 19-01-2024, 09:58 AM
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,920 25-05-2023, 03:55 PM
Last Post: Kaala1
  BFT IGEA BT issue warren5 1 5,773 13-04-2022, 11:49 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,603 02-05-2021, 09:00 PM
Last Post: soother
  Beninca BOB21m Photo cell issue Rossm1987 1 7,804 02-05-2021, 12:39 PM
Last Post: Rossm1987
  BFT C130 Photocell Issue labbetts 0 5,978 25-01-2020, 05:01 PM
Last Post: labbetts
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,533 28-11-2019, 12:11 AM
  Genius Gate System Problem grasshopper 1 14,819 01-07-2019, 09:39 AM
