  • 330 Vote(s) - 3.02 Average
BFT Sub first gate slow to open
Hi: I have a sub gate opening system on my gates . The model includes slowdown & hydraulic lock.
The gate have been installed for about 10 years with normal domestic use.
My problem is that the first gate is slow to start opening and starts to move just before the second gate starts to open .
The hydraulic pump activates immediately, but it seems to have to build up the pressure before the gate starts to open.
I initially thought that is was lack of oil, but it only needed a small amount to top up. Topping up the oil made did not have any effect on the fault.
The second gate works perfectly - pump starts and gate starts to open immediately.
This gate is slow to react on both the opening and closing sequence
I suspect that some sort of internal seal is faulty and I would be grateful for any advice .
A few easy checks will sort out the problem for you,
Can you see any oil leak? if so you will need to purchase a oil seal kit and fit it, messy and time consuming
if not any leaks;
Manual release the unit
slowly push the gate to the open position
unscrew the filler cap on the unit
there should be visible oil near the top (the oil goes down when the gate is closed)
top up if needed
reassemble the unit
run the gate a few times to bleed any air out of the system
all should be ok now
  BFT Gate Motor - Not working elyoussef.ali 1 6,077 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 1,773 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,686 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,783 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,211 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,437 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 4,909 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,479 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,128 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 2,844 23-05-2024, 06:35 PM
Last Post: Zhymke
