  • 373 Vote(s) - 2.84 Average
230v Lyn400 CB11 Board Capacitor req.
Hi - need to buy a new capacitor 6,3 yf but not sure where to buy one?
White one with 2 wires.
We have these instock - call us on 0845 054 5070 or 01384 569 942 to order.
Thanks I found it on your site and arrived today (next day) have fitted and both gates seem to be working fine with the exception that they both open at the same time, have adjusted the delay and one closes a few seconds before the other and overlap, but opening seems to be a bit of a problem?
It could be your motors are wired in reverse and confussing the wing delay. How to check put gates in half open possition and turn power off the board then turn power back on and press remote control once if the gates close then they are wired backwards if they open then all is fine and there must be another problem.
Thanks for the reply - I have the left side as the wing 1 and the right side as wing 2 looking from inside the property as they open outwards. On opening wing 2 looks like it's reacting 1 or 2 seconds quicker than wing 1 but the maglock is holding it until it opens enough to release. Once they have opened wing 2 closes a few seconds before wing 1 and they overlap nicely and close no problem. If the wiring was wrong would wing 2 still close before wing 1?
I would like to delay wing 2 opening by a few seconds and they would be fine.
Probably time to call in the experts, don't suppose you cover Salisbury area?
Sorry We dont Cover Sailsbury but i do know a couple of installer in Andover which is local
GS Gates and Automations - 01264 210088
Web : http://www.gsgatesandautomations.com/
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 9,526 02-03-2023, 03:12 PM
  CB11 Multiple Keypad support Pigsfoot 1 5,629 12-08-2022, 08:14 AM
  Problem with delay time CB11 milan 2 15,413 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Which original remote control is suitable for board CB124 Evan 3 14,468 20-06-2019, 04:26 PM
Last Post: Devs
  LiftMaster SUB300M + CB11 fault jonesy1991 0 12,598 25-01-2016, 02:51 PM
Last Post: jonesy1991
  Opening delay on SCS300 (CB124 board) willows79 0 10,606 02-12-2015, 09:45 PM
Last Post: willows79
  CB11 controller BrianP 2 17,454 16-09-2015, 08:58 AM
Last Post: Gateguy
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,657 29-12-2013, 02:26 PM
Last Post: Tussun
  liftmaster CB11 hold gate open problem sparkey 5 38,168 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 14,345 08-05-2013, 11:32 AM
