  • 345 Vote(s) - 2.74 Average
Came gate opening adjustments
Hello,
We have a pair of heavy gates powered by Came Ferni operators with a ZL19N controller. The closing works well but the opening doesn't. The closing and opening limit switches on the Fernis are adjusted to with 500 mm of the closed position and fully open position respectively, as specified in the book. The adjustments to enable force limitation during closing have been done. During closing the gates move at normal speed until the limit switches then go into slow speed until each leaf contacts the mechanical stop. However when opening, when each leaf reaches it's limit switch, the leaf stops suddenly without going into a deceleration mode as with the opening. The leaves are stopping well short of their mechanical end stops. The result is the arms and brackets as well as the operators are being subjected to excessive forces and the plastic gear in one operator has already failed.
I am a little confused by the markings on the trimmers on the circuit board and wonder if the English translation of the respective function of each trimmer is correct. For example the description for trimmers 9, 10 and 11 on the diagram is:-
9) Trimmer to adjust the stop zone (open/closed position)
10) Trimmer for adjustment of automatic closing
11) Trimmer for adjustment of delay on closing cycle motor n.2
The markings on the board for each trimmer is:-
9) + OP.TIME -
10)+ A.C.T. -
11)+ DELAY 2M -
These instructions have been done:-
ADJUSTING THE STOP ZONE
After setting the slow down spacing (ref. C fi g. 3) with the “adjust microswitches” procedures shown in the gearmotor’s manual…
…take the template - which is supplied with the control panel - and hold it up against one of the two mechanical stops as shown in fig. 1 (adjustment is to be made either on the closing endstop or opening
endstop).
Activate the gate - either using a command button or the remote control - and turn the OP TIME trimmer clockwise until the gate leaf inverts its direction just as it touches the obstacle/template.
Then turn the template from its short side (fig. 2) and turn the OP TIME trimmer counterclockwise until the gate leaf stops against the obstable/template.
With two-leaved gates, this procedure must be performed on either side.
What am I missing?
.pdf   CAME_ZL19N_319U33_v01.pdf (Size: 1.99 MB / Downloads: 3,478)
  CAME F7000 Gate Openers Issue Jackolantern 7 10,111 03-11-2025, 08:46 AM
Last Post: Jackolantern
  ZL92 not opening but closing with videophone Mathi78 0 2,763 11-06-2024, 02:57 PM
Last Post: Mathi78
  CAME sliding gate drops codes after power outage Catch 1 7,324 02-03-2023, 03:18 PM
  ZA3 Came gates not opening with RF device chooper 5 14,950 24-06-2022, 08:58 AM
  CAME ZA3 Not opening & red light (program) flashing RandC 7 112,731 09-01-2022, 11:48 AM
Last Post: dj_singh
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 15,108 23-04-2020, 07:11 PM
Last Post: Luke Scott
  Opening Delay timhurring 1 17,052 09-06-2018, 02:24 PM
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,198 02-05-2018, 06:18 PM
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,627 11-04-2018, 07:25 AM
  Came sliding gate sticking on opening Jellybean 0 12,640 02-07-2016, 06:53 PM
Last Post: Jellybean
