Obtaining capacitors to fit enclosure - Printable Version +- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk) +-- Forum: Gate Automation and Installation Help (https://www.gateguide.co.uk/forumdisplay.php?fid=1) +--- Forum: CAME Automatic Gate Openers (https://www.gateguide.co.uk/forumdisplay.php?fid=4) +--- Thread: Obtaining capacitors to fit enclosure (/showthread.php?tid=6957) |
Obtaining capacitors to fit enclosure - Abbadon - 18-05-2022 I believe i need new capacitors for our Came gate system, as one leaf sometimes now fails to open. The current caps are 16uf, and i can see a number of sources, but i cant find any with slanted top connections that will permit them both to fit in the enclosure whilst still allowing the cables to fit and not clash with the enclosure. I hopefully have managed to attach an image, ignore the circle and arrow that was for my neighbour. Any help locating a cap that will fit in with the enclosure would be most appreciated! RE: Obtaining capacitors to fit enclosure - Abbadon - 19-05-2022 To clarify, another problem is there is NO ROOM to accommodate a capacitor with a base stud, due to the proximity of the transformer to the left, which excludes for of the similar form factor caps that I have found, from being options. RE: Obtaining capacitors to fit enclosure - JamieF - 23-05-2022 Hi, If the 16Uf capacitor doesnt fit you have two options. 1. Find a different shape capacitor with dimensions which fit. 2. add the existing system into a larger IP rated housing, within this you can house the capacitors in a separate area. Best regards, Jamie RE: Obtaining capacitors to fit enclosure - JamieF - 23-05-2022 (19-05-2022, 07:53 AM)Abbadon Wrote: To clarify, another problem is there is NO ROOM to accommodate a capacitor with a base stud, due to the proximity of the transformer to the left, which excludes for of the similar form factor caps that I have found, from being options. Hi, Please see the link below, these may be ideal. https://www.easygates.co.uk/product/16capw/ Best regards, Jamie RE: Obtaining capacitors to fit enclosure - Abbadon - 25-05-2022 (23-05-2022, 09:07 AM)JamieF Wrote:(19-05-2022, 07:53 AM)Abbadon Wrote: To clarify, another problem is there is NO ROOM to accommodate a capacitor with a base stud, due to the proximity of the transformer to the left, which excludes for of the similar form factor caps that I have found, from being options. RE: Obtaining capacitors to fit enclosure - SamA - 25-05-2022 (18-05-2022, 09:34 AM)Abbadon Wrote: I believe i need new capacitors for our Came gate system, as one leaf sometimes now fails to open. The current caps are 16uf, and i can see a number of sources, but i cant find any with slanted top connections that will permit them both to fit in the enclosure whilst still allowing the cables to fit and not clash with the enclosure. I hopefully have managed to attach an image, ignore the circle and arrow that was for my neighbour. Hi, I have done some research and i cannot find a capacitor with slanted prongs. I believe the previous installer would have bent them with some pliers to accommodate the box. Sam. |
