CAME - Printable Version +- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk) +-- Forum: Gate Automation and Installation Help (https://www.gateguide.co.uk/forumdisplay.php?fid=1) +--- Forum: Help and Support Diagrams (https://www.gateguide.co.uk/forumdisplay.php?fid=38) +---- Forum: Information Requests (https://www.gateguide.co.uk/forumdisplay.php?fid=42) +---- Thread: CAME (/showthread.php?tid=6665) |
CAME - tech - 08-04-2020 im looking to add 2 x photocells to my current setup. Currently I have the Frog Kit and photocells on the outside of my pillars, but I would like to add 2 x photocells and post on the inside of gates, so the gates wont close if you approach from the inside of the gates, Also how to I wire these up the existing control box? can I wire to where the existing photocells are connected? please see pics attached, looking forward to hearing from you [/url][url= ]![]() [url= ] [/url][url= ] [/url][url= ] [/url]
RE: CAME - tech - 09-04-2020 (08-04-2020, 11:16 AM)tech Wrote: im looking to add 2 x photocells to my current setup. RE: CAME - RyanB - 14-04-2020 You will need to wire into your CY or CZ with your new photocells. You will then need to configure the safety input CY or CZ to the function you would like using the control panels logic menu. You can find detailed instructions on this if you search ZM3E manual into google |
