Chamberlain ML700 and 940EV - Printable Version +- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk) +-- Forum: Access Control (https://www.gateguide.co.uk/forumdisplay.php?fid=30) +--- Forum: Digital Keypads (https://www.gateguide.co.uk/forumdisplay.php?fid=14) +--- Thread: Chamberlain ML700 and 940EV (/showthread.php?tid=6504) |
Chamberlain ML700 and 940EV - cas2904 - 21-06-2019 I'm trying to get a 940EV to link to an older Chamberlain 700 without success. I have followed the following instructions using 3 times as the enter to select the red learn button but it won't activate. I have already paired a ChamberlainĀ ML700EVGB to the 940EV no problem so I know the 940EV is working. Can anyone suggest another way of getting them to pair? Set Keyless PIN: Program a Keypad PIN Using Your Garage Door Opener:
RE: Chamberlain ML700 and 940EV - JoeF - 01-07-2019 Hi, This is due to your opener not being part of chamberlains evolution range. this is why this will not work for yourself. Please see attached for compatible keypad. https://www.easygates.co.uk/product_info.asp?ProductID=228 |
