BFT sub 24 pivot oil - Printable Version +- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk) +-- Forum: Gate Automation and Installation Help (https://www.gateguide.co.uk/forumdisplay.php?fid=1) +--- Forum: BFT Automatic Gate Openers (https://www.gateguide.co.uk/forumdisplay.php?fid=7) +--- Thread: BFT sub 24 pivot oil (/showthread.php?tid=6473) |
BFT sub 24 pivot oil - Tooltime79 - 12-04-2019 Hello - I am about to set about the installation of a pair of BFT sub 24v underground motors. Looking at the manual (see attached pic) it shows the bottom pivot being filled with oil. I assume this is meant to be the same as the hydraulic oil in the motors as this is the only oil mentioned anywhere in the manual - however would be interested to hear from anyone else who has installed this and whether this is the right thing or whether it should be some sort of grease on the collar instead. Thanks Tim RE: BFT sub 24 pivot oil - JoeF - 12-04-2019 Hi, I believe this oil is for the Ring bracket as such as it is metal on metal which evidently will cause friction. This will most likely be used to lubricate this joint. RE: BFT sub 24 pivot oil - Tooltime79 - 12-04-2019 Thanks for your reply - I agree that it is likely to lubricate the ring bracket - would you expect this to the same hydraulic oil as for the motors, or some other type? Thanks Tim RE: BFT sub 24 pivot oil - SamA - 15-04-2019 (12-04-2019, 05:15 PM)Tooltime79 Wrote: Thanks for your reply - I agree that it is likely to lubricate the ring bracket - would you expect this to the same hydraulic oil as for the motors, or some other type? Hi, It will be the same oil as the hydraulic motors. Sam. RE: BFT sub 24 pivot oil - Tooltime79 - 16-04-2019 Thanks Sam - that's great. RE: BFT sub 24 pivot oil - JoeF - 17-04-2019 (16-04-2019, 06:54 PM)Tooltime79 Wrote: Thanks Sam - that's great. Hi, You would be able to get this from BFT FYI. |
