MOOV B400 - Printable Version +- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk) +-- Forum: Gate Automation and Installation Help (https://www.gateguide.co.uk/forumdisplay.php?fid=1) +--- Forum: Automatic Gates - Help and Support (https://www.gateguide.co.uk/forumdisplay.php?fid=20) +--- Thread: MOOV B400 (/showthread.php?tid=24) |
MOOV B400 - Guest - 01-11-2008 i am fitting MOOV B400 electric swing gates and i have found that they over close passed the central area and then over open. do i need stops? or something to alter the opening area? they are set to 90degree opening and all measurements are correct any ideas RE: MOOV B400 - easygates - 02-03-2009 Hi, Try decreasing the runtime on your control board. You should also have stops on both the close and the open. Hope this helps. |
