  • 294 Vote(s) - 2.78 Average
aster 5 gate adjustment
my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Guest Wrote:my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Hi, you should have physical gate stops in the ground to stop the motor running to the end of its reach. also there should be a function on the board to decrease the motor run time, or there maybe a function to learn where the gates open and close to. you should refer to the manual for this information.
Hope this helps
  Gate kit recommendation electric gate harry 0 181 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 461 28-08-2024, 05:13 AM
Last Post: drewdavis
  Trying to identify this Gate Controller - HOCHE UC109? RossAM 0 721 02-08-2024, 04:47 PM
Last Post: RossAM
  Not Able To Access Data of Sensor Gate hugheshaven 0 1,160 19-06-2024, 10:57 AM
Last Post: hugheshaven
  Gate mobile phone ‘relay’ jam_rs 1 1,797 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 1,849 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 25,202 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Holding the Gate Open mgb 1 5,558 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 5,544 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 4,390 26-05-2023, 02:05 AM
Last Post: Gowrie
