  • 294 Vote(s) - 2.78 Average
aster 5 gate adjustment
my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Guest Wrote:my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Hi, you should have physical gate stops in the ground to stop the motor running to the end of its reach. also there should be a function on the board to decrease the motor run time, or there maybe a function to learn where the gates open and close to. you should refer to the manual for this information.
Hope this helps
  Holding the Gate Open mgb 1 3,816 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,093 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 3,673 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,585 25-05-2023, 03:55 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 20 16,980 15-05-2023, 11:25 AM
Last Post: Nemen3242
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,352 04-05-2023, 04:02 PM
  Electric gate help PLEASE Be8st 5 6,210 18-10-2022, 09:26 AM
  Bft gate one door stopping Matty c 3 7,743 19-04-2022, 09:13 AM
  2014 model BFt rolling gate automation lauriston 1 6,295 07-03-2022, 11:11 AM
  Sliding gate motor brand advice please! Trevreg98 0 5,679 12-01-2022, 08:40 AM
Last Post: Trevreg98
