Threads: 1
0
Hello
Threads: 1
0
Basically, I connected a hikvision relay DS-PM1-O1L-WE to the SBS contacts, I power the relay via STOP and PP as shown in the manual. I do not understand why the opening works when I close the relay via the Hikvision AX Pro where the relay is enrolled, but it only close half a meter or something and than goes to full open again. I tried all settings in advanced settings for SBS (Open - Close - Open - Close etc) to no availability.
Thank you!
Threads: 1
0
(10-05-2024, 03:47 PM)P100D Wrote: (15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Thank you!
Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
As far as I understand, if it is not a dry contact but a wet contact, SBS struggles. DS-PM1-O1L-WE is probably wet contact as well. Shell 1 Plus is cheap and does only dry contact. it will connect to your wifi. no additional device needed and give you your mobile control.
Threads: 1
0
(10-05-2024, 04:35 PM)Nemen3242 Wrote: (10-05-2024, 03:47 PM)P100D Wrote: (15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Thank you!
Threads: 1
0
(10-05-2024, 05:02 PM)P100D Wrote: (10-05-2024, 04:35 PM)Nemen3242 Wrote: (10-05-2024, 03:47 PM)P100D Wrote: (15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Thank you!
Threads: 1
0
(10-05-2024, 05:19 PM)Nemen3242 Wrote: (10-05-2024, 05:02 PM)P100D Wrote: (10-05-2024, 04:35 PM)Nemen3242 Wrote: (10-05-2024, 03:47 PM)P100D Wrote: (15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Thank you!
Thanks so I did a little experiment, and I think I solved out all this dilemma! I connected a wire between the SBS contacts, for the opening it worked fine, and also for the closing. Then what I did next was to keep the wire there for a several seconds. Boom, the closing has the same bad behavior. My Hikvision relay pulse default was 5s for pulse, hence the issues! I lowered that to 2s, all works fine! I'm 100% you had the same issue initially going from the Hikvision door station directly to the Nice. I know because I had to replace an older Nice600, not robus, and that door station relay worked fine!
Threads: 1
0
(10-05-2024, 05:38 PM)P100D Wrote: (10-05-2024, 05:19 PM)Nemen3242 Wrote: (10-05-2024, 05:02 PM)P100D Wrote: (10-05-2024, 04:35 PM)Nemen3242 Wrote: (10-05-2024, 03:47 PM)P100D Wrote: Hello! Could someone please help me with this? I have the exact same issue, however I don't have a hikvision access control unit and have no intention to buy one.
Thank you!
Threads: 1
0
(10-05-2024, 05:47 PM)Nemen3242 Wrote: (10-05-2024, 05:38 PM)P100D Wrote: (10-05-2024, 05:19 PM)Nemen3242 Wrote: (10-05-2024, 05:02 PM)P100D Wrote: (10-05-2024, 04:35 PM)Nemen3242 Wrote: Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
Threads: 1
0
(10-05-2024, 05:54 PM)P100D Wrote: (10-05-2024, 05:47 PM)Nemen3242 Wrote: (10-05-2024, 05:38 PM)P100D Wrote: (10-05-2024, 05:19 PM)Nemen3242 Wrote: I didn't need to try because my other method worked (with access controller). But this should also work. Buy it from amazon, if it doesn't work, you just return it.
I don't know unfortunately
