  • 11 Vote(s) - 3.27 Average
#11
(10-10-2022, 09:58 AM)j1000 Wrote: Hi Joe,
Appreciate any advice.
Thanks for the message,
Could you please give me a call on the number 01384569942 opt 2.
Hi J1000, Joe,
I have the very same issue. Can i ask how you fixed it ?
Thank you!
BR,
Kamil
(16-01-2023, 06:25 PM)Kamil Wrote: Hi J1000, Joe,
Thank you!
BR,
Kamil
Hi Kamil,
Unfortunately we tried several things but nothing worked.
I will reply to your message.
The only thing i can think is that you have set the SBS to pedestrian opening instead of condiminum 1 (L4).
Hi Sam,
Thanks for your reply.
Do you know how I can change the sbs to allow for full opening?
Cheers again.
(03-02-2023, 12:09 PM)j1000 Wrote: Hi Sam,
Cheers again.
As standard, the SBS functions are full opening. Other than "L6" -  Step-by-Step 2 (less than 2” causes partial opening)
Thanks Sam.
Will give that a go.
(03-02-2023, 12:17 PM)j1000 Wrote: Thanks Sam.
Great, any issues let us know.
Hello
I have the same problem:
Were you able to find a solution? I suspect it is due to the “always open” feature. Which i am not sure if it can be disabled
The SBS input should allow for a closing manoeuvre when impulsed in the open position, if the gate is moving a few feet then stopping can you confirm how many times the BUS led is flashing?
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,953 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,715 24-08-2023, 01:34 PM
  Holding the Gate Open mgb 1 3,969 11-07-2023, 01:35 PM
  Nice Moonbus Photocells - Faulty? ddaddy 2 2,175 11-07-2023, 01:33 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,219 03-07-2023, 08:54 AM
  Nice HS400 Andruelectricgates 0 964 09-06-2023, 09:28 PM
Last Post: Andruelectricgates
  BFT gate and Hikvision wiring help Gowrie 0 3,791 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,700 25-05-2023, 03:55 PM
Last Post: Kaala1
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,483 04-05-2023, 04:02 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 4,253 02-12-2022, 02:51 PM
