  • 8 Vote(s) - 2.5 Average
BFT BT A40 Dual Arm
Gate 1 responds and opens (connections on control panel 10/11. Gate 2 will not respond (connections 14/15). On Thalia Control panel.
If I change the wiring connections from one motor to the other - on the board - then motor 2 will work, but motor 1 won't.
So the wiring is working along the run between the two arms but both arms will not open together.
Can you help?
Thank you
Any follow up on this?
This sounds to me like a possible faulty Motor output 1, Have measured the voltage from motor terminals 1?
Mike
Easygates
Thank you for your reply Michael.
Both sides have just started working, in a haphazard sort of way and there is an error code 38 showing!
Will motor output 1 still require reading and how best would I do that?
Thanks again.
(07-02-2022, 04:08 PM)teegee Wrote: Thank you for your reply Michael.
Thanks again.
What control panel are you using? If you can let me know which panel you have, I will be able to provide you with the reason for this error code showing.
Kind regards
-Jamie
