  • 1 Vote(s) - 5 Average
NICE Gate GSM Dialler Relay
Unfortunately an electrician has abandoned a Nice gate install MC824H half through leaving me with 3 issues.
1, I have to connect a GSM 2G Relay.  The gate on pressing of the opens and stays opens and then pressing the fob again closes.  I guess this is semi automatic.
Do I just wire the relay into the open contact on the Nice control unit.  The relay is N/O, 2amp, 0volts and can pulse for either 1 second or 3 seconds or be permanently closed.
2, No safety photo cells were installed - the electrician left some EPMB but the receiver is missing.   However, given this is wired and the drive is newly tarmacked I'm going to recommend a wireless set of:
Nice IBW Wireless Interface
Nice EPMOW Pair of self-synchronised wireless outdoor photocells
Is this right?
3, One Nice Era One fob is programmed and working correctly.  The other fob only opens the gate but does not close it.  I've tried to reprogram this second fob (by holding it next to the working fob) but it just does the same thing.  Do I need to reset the fob and if so how?
Thanks in advance.
Neil
PS as a CCTV installer I've been lumbered with this and just trying to help a little old lady out.
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,847 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,572 24-08-2023, 01:34 PM
  Holding the Gate Open mgb 1 3,803 11-07-2023, 01:35 PM
  Nice Moonbus Photocells - Faulty? ddaddy 2 2,094 11-07-2023, 01:33 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,077 03-07-2023, 08:54 AM
  Nice HS400 Andruelectricgates 0 941 09-06-2023, 09:28 PM
Last Post: Andruelectricgates
  BFT gate and Hikvision wiring help Gowrie 0 3,661 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,572 25-05-2023, 03:55 PM
Last Post: Kaala1
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 20 16,958 15-05-2023, 11:25 AM
Last Post: Nemen3242
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,338 04-05-2023, 04:02 PM
