  • 6 Vote(s) - 2.33 Average
Liftmaster scs
Hi I have a new set of liftmaster scs 324. For some reason I cannot get them to learn the programming for the opening distance. I can get to the point where I open them where I need them
To but they dnt close in the in the final part of the learn mode.  the dgn light is always falshing between 5 lights and 3 lights.
(20-10-2020, 08:56 AM)Athers Wrote: Hi I have a new set of liftmaster scs 324. For some reason I cannot get them to learn the programming for the opening distance. I can get to the point where I open them where I need them
The 3 flashes indicate a wiring issue or poor connection to the control panel on motor 2. This is usually due to the coloured encoder cables being put into the wrong terminals. It can also be caused by a poor joint in the cabling if the cable crosses the road.
If you are using a single motor system you must set the DIP switch 1/2 motor to on. Otherwise the control panel will be trying to detect the second motor which is not installed.
  Liftmaster CB1 / SCS300K - left arm only engages after release then reengage telnet123 2 3,228 10-10-2023, 09:28 AM
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,345 04-05-2023, 04:02 PM
  what size allen key for liftmaster gatestop and bolt? bomitie 2 12,481 01-06-2021, 04:04 PM
  Liftmaster scs Athers 0 12,942 19-10-2020, 08:08 PM
Last Post: Athers
  Liftmaster LYN300K, 400K zappahead 1 22,716 12-04-2018, 03:30 PM
Last Post: Tim
  Wanted - Liftmaster SUB300M Motor pigsfoot 1 21,017 03-06-2015, 04:07 PM
  >> Liftmaster CB11 Support Diagrams << easygates 1 26,379 27-04-2009, 12:49 PM
  >> Liftmaster CB24 Support Diagrams << easygates 3 31,671 27-04-2009, 10:58 AM
  >>> Liftmaster CB24 Simple Setup Guide <<< easygates 0 17,562 30-03-2009, 04:27 PM
