  • 5 Vote(s) - 2.4 Average
MC824H with Toons - learning process
Hi hope you can help.
Just installed this but at this stage have nothing connected other than the arm.
I go through the learning process, set the gate at half way point, it duly opens then closes, the opens again and stops. I expected it to close then it would have learned. I press open close buttons but nothing. I'm sure I must be making a simple mistake. I have dipswitch set for 4 for to5024, have also tried dipswitch 1. Appreciate any advice/help.
Once I have achieved this I will then add bluebus/remote, etc.
Hello,
All that is required is to change the polarity of the motor cables swapping the blue and brown cores. Complete the process again and the gate will end in the closed position.
Worked a treat. You can also attach gate arm to a 18v power tool battery to test.
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 2,116 04-01-2024, 10:06 AM
  Mc824h hold open Simonizzy 2 17,298 20-07-2020, 10:00 AM
  Wiring photocell to MC824H davidja 2 14,347 14-04-2020, 02:17 PM
Last Post: davidja
  MC824H Simple Programming Guide easygates 2 21,666 25-03-2016, 09:43 PM
Last Post: Henwood_1988
