  • 20 Vote(s) - 2.55 Average
Came gates
Hi all, help needed.
I have a set of came ati gates, pcb za3 and until a few months ago  were working fine. I had a problem with them not closing, this was resolved by removing the wiring  from the photocells, intercom and push button in the house, and connecting terminals 2 and c1. Just recently I had a local company quote me £500 to reconnect the photo cells, intercom and push button which seems extremely expensive. The guy said some of wiring needed replacing.
I'm an electrician by trade, but just need help in knowing how the wiring goes for reconnecting the external components on the terminal block.
Also the dip switches, not sure wether they were changed when the original problem occured. So would like to know which ones need to be on or off.
Thanks in advance Martin
Ps. The intercom is a videx gsm 4000 series
(04-07-2019, 10:25 PM)Ring8180 Wrote: Hi all, help needed.
what brand of photocells do you have are they hard wired or battery photocells?
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 7,891 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 16,759 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 5,804 14-11-2022, 11:59 AM
  My Came ZM3E gates won’t open golfnut75 1 5,281 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 7,345 24-06-2022, 08:58 AM
  Came Gates - power cut issues Paddy_SP 2 7,202 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  Came Double Swing Gates opens by itself for some centimeters risp73 0 8,636 19-06-2020, 06:19 PM
Last Post: risp73
  Frog - ZA3: gates won't open BarryD 0 10,234 15-06-2016, 01:34 PM
Last Post: BarryD
  CAME double gates - one side closes but will not open crliving 1 17,378 02-08-2013, 09:39 AM
Last Post: Blakey111
Rolleyes 400 Newton limit on boarded gates Paul smith 3 21,796 12-01-2012, 11:20 AM
Last Post: sebabastek
