  • 33 Vote(s) - 2.79 Average
Swing Gate arm not moving!
    I’ve just joined this forum minutes ago and having some problem with the actuator arm of the door gate. At first the door wasn’t closing properly on the right side, I thought by moving the screw ballnut ( attaches to the door bracket) rotate it manually so that it pushes out which eventually shut the door properly but as soos as I’ve done that the electric motor don’t rotate, I had even swap the electric motor with the other actuator and still does not turn!!, please help!.
The controller is from CAME.
Thanks,
IHere are some pictures of the controller and actuator:
[Image: IMG_9811_zps53rbveha.jpg]
[Image: IMG_9821_zpsamvn92vy.jpg]
1)check whether the voltage is supplied to the motors after you pressed remote control
2) check capacitors
(18-01-2019, 11:31 PM)Automatic-TC Wrote: hi
1)check how affordable these amazing probiotics for gut health are and whether the voltage is supplied to the motors after you pressed remote control
2) check capacitors
How do you make sure that the voltage is supplied to the motors after pressing remote control btw?
Hi!
(13-02-2019, 02:55 PM)Stacker Wrote: How do you make sure that the voltage is supplied to the motors after pressing remote control btw?
Can you hear your motor moving but it isnt engaging the drive shaft?
If so check your capacitors.
To also check your voltage you would need a Voltmeter.
If not possible look for signs of power Ie. LED's or some sort of movement.
Also check your panel and remove anything from the stop input to see if it works then if it does there is a fault in this input whether it be a short in the cable or so fourth.
  Could Someone Give me Seeking Advice on Gate Installation for Home Security? tysonzach 0 14 Yesterday, 06:49 AM
Last Post: tysonzach
  nice gate openers John Thorpe 1 3,915 19-08-2022, 03:14 PM
  CB11 gate opener testing me!!!! lou trudge 0 5,162 22-12-2021, 10:40 AM
Last Post: lou trudge
  Gate sensors does not work when raining vanbinh 3 9,747 02-06-2021, 02:45 PM
  Gate Rail Sweeper/Brush Privateersman 0 6,781 10-02-2020, 03:50 PM
Last Post: Privateersman
  GIBIDI gate motor closing problem davidcunningham 0 8,816 26-04-2019, 08:20 PM
Last Post: davidcunningham
  Help identifying electric gate fob Nick180582 5 23,471 22-10-2017, 01:22 PM
  Diatem Gate Keypad - removing cover hazel.luskin@gmail.com 0 7,407 20-05-2016, 11:28 AM
  electric gate servicing sparkey0151 1 12,432 02-07-2015, 12:57 PM
  BFT Oro Swing Gate Openers GGTech 2 13,494 02-07-2015, 07:01 AM
Last Post: GGTech
