  • 58 Vote(s) - 2.86 Average
BFT alpha and loop
Hi dear friend, I have installed a BFT moovi which comes with alpha board, I also installed loop for exit , now when a car pass over loop door open when second car pass over the loop the door freeze hence I made dip switch on loop dedicator as delay 20 second while door has also delay of 20 second , this solved the issue temporary, I am new to gate barriers and I can see that when and order come while a door is opening period it stop the door and hang it does not go up or down and we need to use the remote any suggestions   I have attached the manual for reference
  BFT Urano ground loop muturola123 0 3,678 31-01-2019, 11:36 AM
Last Post: muturola123
  Fitting a bft kit with rigel 5, photocells, keypad, loop detector help easygates 1 22,380 14-05-2010, 01:01 PM
