  • 146 Vote(s) - 3.14 Average
Rigel 5 and sub r
Khi new here  I was wondering if anyone point me in the right direction on how to program check the program of Rigel 5
Problem I’m having is one of the gates works correctly and one gate just move a tiny bit in closed or open  Motor was taken out and as been test at  Electric motor repair shop came back Woking ok
Could  it be the capacitors or
programming of the gate control as the Son try adding new remotes Controls
Hi Steve,
Thank you for your enquiry, i will post below the manual for the Rigel 5 board which will help with programming and error codes. I would advise you to check the motor output terminals on the board if the motor has come back from testing as not faulty. If you are getting the correct voltage once a command to the gates have been given then i would be checking the capacitors, this can be done by swapping the capacitor from the working motor to the motor that isn't working. If the fault moves from motor to motor then we know that this is the problem. Hope this helps and if you need any more assistance don't hesitate to contact us.
http://manuals.easygates.co.uk/PDF/misc/bft-rigel-5.pdf
Kind regards
Tim
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,097 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 1,219 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,560 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 4,688 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,157 13-04-2021, 02:41 PM
  But Rigel 5 and Deane a15 cells Matt Hey 2 8,770 30-03-2021, 07:57 AM
Last Post: Matt Hey
  Bft rigel 6 PHCL tidoh2021 1 11,759 12-03-2021, 07:31 PM
Last Post: russ
Smile Rigel 5 Manual override Stramorebees 0 10,096 20-09-2020, 12:03 PM
Last Post: Stramorebees
  BFT Rigel 5 Issue kw1 0 9,629 16-08-2020, 02:04 PM
Last Post: kw1
  Wiring Compacta photocells to Rigel 5 rjmoore 0 10,873 11-05-2020, 06:51 PM
Last Post: rjmoore
