  • 153 Vote(s) - 3.28 Average
Daitem D5131 handset help!!!
I have a daitem entry system comprising a D5131 handset, D5200 control box and D5821 panel with keypad. The batteries went on the handset so they were replaced with rechargeables. Since then although the handset has icons it does not connect and I cannot get a radio signal on it by going through the pairing instructions. We found the antenna to be damaged but have replaced that.
Any advice and any replaceables would be welcomed!!
Unfortunately this will probably be a handset fault, however the spare parts are no longer available for the D type analogue system. You now have to convert the complete intercom system (Call point, Receiver & Handset) to the new digital system which can be found in the link below.
http://www.easygates.co.uk/product_info....ductID=678
(22-12-2017, 09:39 AM)Sav Wrote: Hi,
Thank you - thought that may be the case! Hopefully someone will have a handset they may wish to sell as replacement of whole unit not an option at the moment!
  Help needed with daitem handset shazbah 3 81,357 17-10-2019, 12:25 PM
Last Post: Hartley10
  Daitem door entry system tfotransport@hotmail.com 0 50,946 15-10-2019, 09:27 AM
Last Post: tfotransport@hotmail.com
  Daitem SC100AU 1 controller 2 access points? Window 0 4,287 07-06-2019, 10:53 AM
Last Post: Window
  DAITEM WIRELESS INTERCOM how do I change entry code?? Help! Scarlett 3 22,623 04-05-2018, 07:43 AM
Last Post: Gagobaa
  Daitem Wireless Intercom caller unit not working GemOpy 2 19,132 02-10-2017, 10:47 AM
Last Post: GemOpy
  daitem handset faac gates & remotes doon1968 0 7,102 28-08-2016, 05:12 PM
Last Post: doon1968
  Replacement Daitem D5131 Ningana 0 6,996 18-06-2016, 07:03 PM
Last Post: Ningana
  daitem d5131 indoor controller issue hirst007 1 14,114 02-07-2015, 01:13 AM
Last Post: thm
  daitem door phone and Proteco gate driver peteygateman 1 16,359 07-04-2014, 11:06 AM
Last Post: Blakey111
  Daitem Handset User Instructions peteygateman 1 16,340 18-03-2014, 04:56 PM
