  • 154 Vote(s) - 3.17 Average
liftmaster cb124ev
Hi everyone i was looking for some help to wire the control box.
most of the terminals appear straight forward within terms of being labeled up
however the transformer has 2 spade connectors which i can see where they go I'm just unsure of which way round
also has a blue and brown again same problem
any help would be appreciated
cheers lee
(07-10-2017, 01:41 PM)leescafe Wrote: Hi everyone i was looking for some help to wire the control box.
cheers lee
thin wires goes to 240 v
thicker wires goes to 24 v
It is good to check it with an electric meter !
Best RegardsĀ
TomĀ
ok i spose i could trace the back of the board to see wich way round the live and neutral go. the 24v side has 2 identical spade connections can they be put on any way round?
and thanks for the help by the way
(08-10-2017, 06:48 AM)leescafe Wrote: ok i spose i could trace the back of the board to see wich way round the live and neutral go. the 24v side has 2 identical spade connections can they be put on any way round?
HI spade connections can go either way round its AC
Thankyou
  Liftmaster sub 300 set up Iceice54 1 5,513 05-01-2020, 01:26 PM
Last Post: Iceice54
