  • 137 Vote(s) - 3.28 Average
Lead gate only opening a few inches.
Rolleyes
Hi Im a DIYer
My system - Bft SubR. Rigel 5 control board.
My lead gate is only opening a few inches then stops.
Do I need to top up the hydraulic oil.
When topping up hydraulic oil do I need to isolate the mains power supply and use the Triangle key to disengage the hydraulics. Im afraid hydraulic oil will spurt out under pressure from fill port.
Yes the oil does sound like it could do with topping up, the problem you have is that air may be inside the motor which will still continue to cause a problem even after topping up. It sounds to me like you could do with a potential service by a gate automation installer before it becomes quite costly.
Hi Sav
Thanks for your reply. I ordered hydraulic oil and when I went to top oil up noticed that it is Full.
The air lock might be the problem. Can you tell me where the bleed valve is and how to go about bleeding.
I had this motor repaired by service engineer only few months ago. He had motor & pump away for weeks and when he reinstalled again the gate was half as slow opening & closing then now only opening few inches.
I will not go back to this firm as very dissapointed with their work, they didnt even have a grease gun and didnt service gates when i asked.
  Gates Opening After Closing tht7 2 9,616 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Holding the Gate Open mgb 1 3,769 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,044 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 3,630 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,544 25-05-2023, 03:55 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 20 16,845 15-05-2023, 11:25 AM
Last Post: Nemen3242
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,301 04-05-2023, 04:02 PM
  Electric gate help PLEASE Be8st 5 6,171 18-10-2022, 09:26 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,376 24-06-2022, 09:54 AM
  Bft gate one door stopping Matty c 3 7,720 19-04-2022, 09:13 AM
