  • 108 Vote(s) - 2.9 Average
Centurion D2 problems
Firstly, sorry if this is in the wrong place, not sure where is the best place to put it and figured this would be the most knowledgeable place.. So please move if required.
I have installed a centurion D2, In the open position, the origin is mounted 500mm back from the origin switch on the motor. I put the gate in the closed position and lock it, then commence the auto limits setup. During the setup, the motor finds the origin fine, and the setup goes smoothly and completes.
However, after switching back to "run" mode, the gate closes without issue, however, when opening, the gate is almost fully open but slows down before it hits the origin, once the origin is found that gate stops, leaving it about 500mm still open. It then times out after about 5 seconds and closes, without reporting any error.
With the motor disengaged, the gate moves freely and was moving freely during the limit setup process. So I doubt it is current limiting.
Any ideas? I'm really stuck and im SUPER desperate to get this one invoiced out!
Thanks!! Smile
  Wifi Gate Opener - IT4WIFI problems Mehullakhani 0 6,733 12-08-2020, 11:08 AM
Last Post: Mehullakhani
  Dieffmatic gate problems MaryK 0 7,552 01-07-2019, 07:59 PM
Last Post: MaryK
  Safety beam batteries and arm problems Laminator 1 7,222 24-07-2018, 07:22 AM
  Proteco Q36a problems gentle9 0 6,917 27-07-2016, 12:07 AM
Last Post: gentle9
  Major Problems with Q71B and MyHook Motors roundyuk 1 10,988 26-09-2013, 11:46 AM
Last Post: Blakey111
  RIB loop problems Arv 0 7,417 01-09-2011, 09:32 PM
Last Post: Arv
