  • 150 Vote(s) - 3.09 Average
PROTECO Q60S BOARD
I have a gate motor which needs to be recalibrated, as it is not finishing its cycle correctly. It closes but will not respond to an opening pulse, but will open if you break the safety beam. I know how to reprogram the board, but the board is showing that the limit switch has been reached and won't allow me to go into the sequential programing. How do you delete the settings, leaving the radio codes?
  Q60S/R - Error code "P" DanyJee 0 7,337 04-06-2016, 10:42 AM
Last Post: DanyJee
  Board showing red dot when transmitter pressed, not opening though SamuelWestwood 1 8,951 13-05-2016, 10:49 AM
  PROTECO Q60S/R FAULT AND INSTALL jeffducati 11 69,795 18-06-2012, 09:58 AM
Last Post: Proteco_UK
